disenter said:interesting, believe i could get 133mhz out of the fsb, just not with the ram i have, see the 133 clock is only very slightly higher on the pci's and agp, where as everything in between that an its lowest/default setting is actually higher, so to the pci's an agp theoretically it should be fine.. the problem was the sdram i am using wont take it.. its only pc-133 hyundai crap.. i need 166mhz stuff to do it .....
FRANK said:. This is a well documented problem with all of the first generation Socket A motherboards utilizing the KT133 chipset, and for that matter, the earlier KM133 chipset found on the Slot A motherboards.
Angry said:
You mean KX133...The KX133 was revised for the socket A platform and to fully be compat with Thunderbird cores where as the KX133 was a hit or miss if a Thunderbird cored Slot A worked...
And FireMogle...
I would like to see these hardcore mods as to try them out on a KX133 chip for my Slot A board...
