I am in need of technical support. I have an asus a7v266-e motherboard with 512 megabytes of ddr 2100 memory, an amd athlon xp 1600+ cpu, a geforce 4 ti 4600 video card, a soundblaster live 5.1 sound card, and a generic 56k modem. My configuration has been the same for the last few months, and has been working perfectly. Within the last week or so, my system has stopped booting. I cannot even get into bios. I have tried other video cards in the same system, and it still does not display anything. If I try the geforce 4 in other computes, it does work fine, so the problem is not the video card. The problem is also not because of the monitor, which works fine if connected to other computers. The fans on the motherboard including the cpu fan do spin if I power on the system. The cd rom drives open and close. The problem is that nothing whatsoever appears on the monitor when I try to boot the system. I've been running with the "jumperless" settings enabled, and it's worked fine. I tried to set the jumpers manually to see if that would help, but it still doesn't boot. I flashed the bios using the asus update program on the same night that the computer stopped working, so I'm wondering if that might've caused a problem. I used the 1011 bios, I believe, from the ftp.asus.tw site. The system started displaying letters and numbers all over the screen shortly thereafter, even in bios. It would start to boot, and then reset itself suddenly. Then, it stopped displaying anything on screen at all.
Help would be appreciated, as I would rather not purchase a new motherboard if I can help it. I only bought the motherboard recently, I would assume it's still under warranty. If I cannot get it to work, and it proves to be defective, how would I go about getting it replaced?
Thanks in advance,
-Michael A. Pasqualone
[email protected]
Thanks in advance,
[email protected]
