A7V8X-X Problem please help
Steven4563
Northants England
i have a Asus A7V8X-X motherboard with pc3200 in the bio its set as 400ddr but in sandra i only get 1438m/bs bandwidth ive reformated my comp and still the same can anyone help me ??
thankz
Robbiesan
Canada
Hi Steven. What is your current config? if your CPU is still runing at 140fsb that would explain the slowness.. in general you should keep your memory synchronized with the CPU.. so, if you are running 140fsb your memory (if sync'd, 100%) will also run at 140MHz which is quote slow. You may wany to back down the multiplier to maybe 11-12.5 and up the fsb bus.. if you can get it up to 180+ your memory bandwidth will increase..
Please let us know exactly what you have and how it's configured in BIOS.. have at my sig for that..
Steven4563
Steven4563
Northants England
ive upgraded my system to
asus A7V8X-X motherboard
512 Meg PC3200 DDR Ram
Samsung 20gig h/d
2100+ running @ 1.73ghz 133fbs
Asus Geforce4 Ti4200 128meg
Robbiesan
Canada
Steven, it's your FSB setting that's holding you back.. if you can increase it you will see memory bandwidth increase..
Steven4563
Steven4563
Northants England
ive set the fbs at 146*13 with 1.850 volts coz its a pally and i know they dont overclock well im still trying to hit higher fbs thankz guy
Steven4563
Steven4563
Northants England
i cant go no higher than 146fbs with 1.85Vcore and i dont really want to go higher with a volcano 9 could anyone tell me how to unlock the multi's on a 2100+ pally please
thanks
Robbiesan
Canada
try turning down the multiplier to maybe 12.5 - 11 and turn up the FSB.. that would help to increase memory bandwidth since it is in direct proportion to the CPU FSB.. also, this would be better for your CPU.. 1.85v will generate a lot of heat which is fine if you have some serious cooling..
