A7v8x-x
Tyman
Canada
Using Xp 2500 cpu,bios# 1007,cpu speed set to manual,cpu frequency multiple set to 13.X,cpu external frequency(mhz) 166/33, memory frequency 333(to match 1gig of pc2700 ddr ram frequency.)If you run the unit at those settings which gives 2.17GHz, its just not as stable as at a lower multiplier of say its stock(11.0X) or you can use 12.5X(2.08GHz.)All voltages stock, unit cool volcanoe,1side fan ,1 rear case fan(both high output volc's)unit is cool.. this would not be unusual am I correct?
