A8N32 FSB speed - what's yours ...?
QuietIce
Disabled
Anywhere but there
I've recently encountered an odd issue with the A8N32's FSB speed. Several months ago, when I was considering my first Opty 165, I checked the FSB speeds on the two boards I had running at the time. I tested both of them up to 340 FSB thinking I wouldn't need any more speed than that for a 165 (340x9 = 3060). Last week I started building my wife's machine and had three other boards to pick from so I chose the newest one I had, a rev. G board, and installed a 165 LCBQE 0711SPAW.
Everything was going really well - I was up to 310 FSB and still at 1.30 vCore. Then I bumped it again and found I needed 1.35 vCore for 320 FSB. I wasn't too unhappy about that, 2880 at stock is still pretty good! :) After that I couldn't raise it any farther. At first I thought the chip had hit top end but it seemed odd b/c the vCore was still very low, though some of the newer Opty's OC like that. But when I started checking the FSB I couldn't get it over 321 MHz even at 7x and when I went to NB over-volt (NB/OV) I got to 325 but couldn't get to 330. :-/
Today I went back and tested the other boards a little farther than before since I hadn't recorded the tests (just to make sure I hadn't lost my mind - old age, you know ;)). One board tested to 350 FSB and needed the NB/OV above 320 MHz (5 MHz steps). The other got past 355 before needing the NB/OV, then went on to 365 - at 370 I got a BSOD. Now keep in mind I only tested the last two boards with SuperPi 1M but I would think that sufficient for the FSB only - the CPU (@ 7x), RAM (200<RAM<250), and HT link (<1000) were all slightly below their tested stable speeds (is this an incorrect assumption???). So now I'm curious how high other A8N32 FSBs have over-clocked.
What's your highest FSB and is it rev. 1.01g ...?
I dunno what Rev my board is, but I'm stuck @ 250x12 with my FX55. Anything over 250 will fail to boot. Not sure if it's my board,ram or chip :-/ .
never liked dropping my multi, ive been to 310x10(not stable), never saw a better clock with a 9 or 9.5
right now im at 290x10 but its not stable cause im giving it some low voltage
dunno what my revision is, got it last march-april(2006)
Thanks for all your responses, guys!
Seems I may have gotten a couple of good boards and a so-so board (the "g"). I haven't seen a rev. g top out much over 320 yet, though, so maybe it's "normal" after all ...
*Edit*
Just found my board is a Rev 1.01 NON-g :-/
Well I had a rather disappointing thing happen last night. After shutting down the system and changing out pumps the darrn thing wouldn't reboot! :mad: I had to bring the FSB down to 316 (w/NBOV) to get it stable again.
You'd think rev. g would be better but it seems that's not the case. :(
Nebulous said:
*Edit*
That's a GOOD thing! But I was pretty sure it wasn't your board - not at a 250 FSB. Anything under ~310 MHz is OK for both boards, anyway. My WAG would be RAM but my FX-55 (SD) also topped out near 3.0 GHz (@ ~1.45v) so :shrug:
The good news is, if your RAM will go higher (and it should) you could change to 273x11 and maybe still keep the 1:1 setting - or have you already tried that ...?
Tried that QI, no dice. Dunno what's holding me back :shrug: I went to OCZ's site and asked why my ram won't go above the 250. They said 2gb's of ram will not clock as high as it's 1gb counterpart :rolleyes:
We'll see if the new psu will make a difference.
billb said:
It's pretty easy to find out with multipliers and dividers and an unlocked chip like an FX55.
Hmm, if it was I would know :p I tried it all, and still a nogo. Before i got this OCZ, I was using Corsair XMS4400 and I had no trouble getting 300+ from them. I got this OCZ ram and it will not run pass the 250.
So if you have any suggestions/ideas, i'm willing to try again :D
I take it you've tried dropping the memory limit down to 166 before pushing the FSB higher?
Did the Corsair crap out on you - or did you put it in another machine ...?
Corsair crapped out so i rma-ed it. The XMS4400 was discontinued and obsolete so the what i got as returns were XMS4000 Pro's, the ones with the purdy LED's on 'em :-/ I traded them for the OCZ's i have now.
Now why would i want to drop the ram divider? The whole purpose is to run the ram @ 1:1 isn't it? Drpping the divider would just defeat that.
*Edit*
Max is 310
Divisor @ 166
2.9Vdimm
HTT 3x
Multi: 10x
HT Voltage Enabled
Vcore: 1.5v
Unstable :-/ Figured 300 is the max before she craps out.
Nebulous said:
Max is 310
Divisor @ 166
2.9Vdimm
HTT 3x
Multi: 10x
HT Voltage Enabled
Vcore: 1.5v
AAARRRGGGG!
Is the memory stopping or is the CPU stopping at 3.1ghz?...You don't know!
310 FSB, 166 Divider, and a 10 multiplier runs the memory at 258.33Mhz and the CPU at 3.1ghz
Ok...which one is failing?
...and how do you know?
*Edit*
Max is 310
Divisor @ 166
2.9Vdimm
HTT 3x
Multi: 10x
HT Voltage Enabled
Vcore: 1.5v
It is important to push the RAM to the limits but CPU speed is the king with RAM in second place. If you want to stay at 1:1 that's easy - try 239x13 and see if that works. On the POS motherboard I've got I was running the FX-55 @ 230x13 (on water) with the RAM at 1:1 - I couldn't push it any higher due to a lack of voltage controls. :-/
And on my caseless machines I like them purdy RAM lights - it lets me know the rig's still runnin' ... :)
Well found out the ram goes up to 310 using an 8 multi and 3v on the ram. So my guess is the chip itself maxes out @ 3.0GHz. Maybe 3.1GHz, but I don't like using more than 1.55vcore.
I agree with that - 1.55 vCore is my self-imposed limit, too.
If the chip tops out at 3.0 GHz and your RAM will run 300 then I'd run 300x10 @ 1:1. You should get a lot more RAM bandwidth and a little better performance that way ...
Yeah, that's what i was thinking too. Once i get the new psu then I'll go for it ;)
