Ok, I have these parts
Asus A8V deluxe. Serial is 46xxxx
Athlon 64 fx 53 (retail)
2x512 of Corsair XL pro 3200
Ati 9700 Pro (retail ati) (Waiting on x800xt =>)
2x36gb raptors using onboard sata raid in a stripe.
Antec 430 ps.
Original Prometeia (with heated backplate) (not in this setup yet till i get the damn thing solid at stock speeds)
Xp Pro (legit Copy)
Dx9b
SuperPi 1m=35
Ok heres the problem.
Since I have built the system, it randomly hard locks in windows (as in screen still being displayed with whatever was on the screen.). I first noticed this in Prime 95 after about 2 hours. This is with all auto timings on memory etc.
Next, I went through and manually set all the timings, same result.
Next, I replaced the heatsink with a zalman and put some as5 on it, same result.
Next, Tested memmory with Memtest86, no issues.
Next, I flashed bios to 1006 from asus.com, same result.
Next, I flashed bios to the beta one that was in a couple threads down.
Im running prime 95atm and wont know for another couple of hours if it works now or not.
Anyone got any ideas.
Im using latest ATI and Via drivers.
Onboard audio is enabled and using drivers off of cd for it.
The system has yet to lock in a game, but has locked several times while browsing websites. Its sorta disturbing considering I spent quite a chunk o change on this upgrade.
Also, by auto, the bios sets the memory at 2t instead of 1t. At 2t sandra scores much lower. Is that normal? (the auto to 2t)
I have read several boards with people complaining of the A8v with Ati cards. In my atempt that is going now I have disabled agp write through smartgart program.
My 9700 has always ran sorta hot for my tastes and has a pci slot cooler under it.
I have also replaced the back 120mm fan with a higher flowing double thick antec.
I have tweaked the voltages up on memory and proc.
The memory voltage being upted seems to have made it happen less frequently. But being it takes at least 2 hours for the lockup to happen, I havent had a chance to test everything I would like. I would like to try it with agp set to 4 in bios, but would like your opinions first.
ALso, what is normal temp for an fx53? Mine runs around 55c under load. Thats with the big zalman heatsink (cant remember name).
Finally,
Does Prime95 put any load on the videocard that would cause it to heat up?
Ty in advance for help.
edit: Running asus probe software. my voltages look good and are solid, except vcore is going from 1.485-1.502.
Antec 430 ps.
Xp Pro (legit Copy)
Dx9b
SuperPi 1m=35
Finally,
