Abit At7 Max 2 Via Kt400 Socket A
Remove
Mobo + ram ?
ABIT AT7 MAX 2 VIA KT400 SOCKET A
ABIT KG7
ABIT KD7
Will these boards handle a stick of REGISTERED DDR DIMM 512MB PC2700? I'm easily lost when it comes to checking memory compatabilty.
Thanks! :)
Chris
England, UK
Yes they should support that RAM I know my AT7-MAX does so I doubt the newer boards will have a problem. You dont need registered RAM for that board though so if your buying new don't bother, although if its just a stick you have lying around it should be fine.
-Chris
Remove
Remove
Yeah I have some extra that no one seems to want to buy or trade so I will use it.
Thanks
