Abit AW8-Max memory compatibility?
Ach3r0n
What brands/type of memory has everyone tried on these boards (and what bios revision do you have)? I'm partial to Mushkin but I've been told it doesn't work with this board. :( Anyway, what does work?
Rocinante
Houston, TX
I run Corsair XMS2 PC6400 (DDR2-800) works like a champ...the initial auto setting sets the timings pretty high for compatability, but I just set them back to spec manually...
A
Ach3r0n
hi again Rocinante. :)
What bios rev. are you running with the Corsair?
batboy
Senior Moment
Kansas, USA
As far as I know, the new BIOS 15 has some bug about running DDR2-800 RAM at the 1:2 ratio. My understanding is that Abit is currently working on fixing that bug with a new BIOS update. As long as you don't have a Presler or Cedar Mill CPU, you can use the BIOS 14 to avoid the problem.
Rocinante
Houston, TX
I'm running BIOS 14...I usually don't update once I've install my OS unless I'm having a problem...next BIOS update for me will be in about 2-3 months when it's time to format...
I'm not using the 1:2 divider either...I think I use the 3:4...too lazy to calculate it... :shrug:
A
Ach3r0n
Unfortunately, I will be running a Presler. :(
