Abit be6-II voltage hack?
T
Tran
Guest
I can´t get the voltage beyond 1.75 volts, (using fcpga celeron II)
i´ve tried to reflash the bios at 1.75.. dosn´t change a thing..
wasn´t there some kind of voltage hack or something?
What kind of slotket are you using? Setting the slotket voltage jumpers should change the range of Vcore in the bios.
Yeah like Tim says: if you have a slotket with voltage manipulation, just set the voltage to 1.7v and then go into the BIOS and you *should* be able to choose 1.9v now. If you want even higher voltages in the BIOS, set the slotket voltage to 1.8v.
I've tried changing the voltage on my Slocket !!!, on my Abit VT6X4 for my celeron 600, but it never boots!! Do I need to do something special? Like change a few settings on the mobo?
