- Dec 13, 2001
OK, I'm not sure if this is the proper place for this, so if not, I apologize. Mods, please move it to where it belongs if need be...
I have an Abit BE6II v2.0...It's about 1 1/2 years old, I noticed months ago the capacitors surrounding the cpu slot were starting to buldge. I knew eventually they would need to be replaced as I have heard that this exact thing has happened to many other people, but, I left it alone. Two days ago, one of them decided to finally go, and go it did!!!
OK, so I thought that the board was beyond saving at this point but still my curiousity got the best of me. I wanted to see if the board still worked so I found the nearest match to the capacitor that had litterally popped off the board and did a temporary solder job just to see if it would power up.
Behold! It did power up and ran fine...WHEW...it still works, what a trooper.
Now, my question to you, the person/people reading this is:
I need to replace all the failing capacitors, that have the values as follows:
TYPE: Radial Electrolytic capacitor - VALUES: 1500uF 6.3 volts ( I need 11 of these )
TYPE: Radial Electrolytic capacitor - VALUES: 1000uF 10 volts ( I need 2 of these )
The problem is, I CAN'T SEEM TO FIND THE 1500uF ONES ANYWHERE!
Anyone have any suggestions where I could find these?
What about replacing them with higher tolerance components, if so, what would be a better value to use in place of the original 1500uF 6.3v ones? ( I have forgotten much about electronics, and I have no time for doing homework...
Any/all help is appreciated, as this board was rock solid and recently retired to being a backup gaming system on my home network..( used only when friends came over to DIE playing TAC OPS and other stress relieving games...
