I flashed the ss bios and I still cant set my voltage over 1.70 . Im trying to get Celeron 566 at 850. Does alright a 1.70 but 3d games crash eventually.
I know this works. It worked for me and I posted it for someone else last week and it worked for them. Set your voltage to the highest available setting in your bios. Reflash the SS bios using this command line:
awdflash bh6_ss.bin /cc /cd /cp /py /sn /cks /r
When you go back into the bios you will have higher voltage selections (I think up to 1.85v or 1.9v). If you need more just repeat the procedure setting voltage to max and reflash. Let me know how you make out.
You should definantly get higher than that. My BH6 runs normal at 2.0v and I can take it up to 2.3v. This is both before and after I flashed it with the SS rev.
