SOLVED Abit BP6 and FC-PGA processor compatibility
D
Death
Guest
I own a BP6 motherboard that right now has 2 C366 PPGA processors. I have overclocked this board to [email protected] volts.
I am interested in putting in some faster chips but cannot figure out what they will be.
This board will not support the FC-PGA processor without some hardware modifications and I am planning on doing them.
My question is what chips should I use. I have heard many ppl's success stories with the PIII 800 mhz with the 100 MHZ FSB. I wouldn't mind putting in a couple Celeron 2 processors either as long as they still work in SMP.
If you would be so kind as to post your success stories on overclocking the FC-PGA processors and what motherboard you are using. If you are using the BP6 please give details on how you made it happen.
Thank you.
I know I will need them but right now I just want info on the best Processors. Also on the BP6 you can't just use the powerleap adapter you also have to modify the board.
