LutaWicasa (Mar 16, 2001 11:53 a.m.):
This old trick worked fine for me. Go into bios and set your voltage max. Re-flash the bios using /sn/cc switches. Use F10 to exit flash prog and re-set to start. Go into bios and set everything up. You should now have options up to 2.1v, however on my board it will only use up to 2.05v. Anything over that and she does nothing
