ABIT IC7/IC7-G/IC7-Max3/IS7-X Failsafe Overclocking BIOS settings. Read First!
I've seen alot of posts in the last couple of months with troubles regarding instability and overclocking.
I thought I could post the basic BIOS setup to get a good
overclocking start. The images shown here are version 1.9 for IC7. The layout of the BIOS is similar, if not the same, on all the IC7 and IS7 series of motherboards.
This is the Soft Menu Setup with the settings I recomend for a start:
People with 2.8C CPUs or higher might not be able to post with this FSB, start at 200 and find a sweet spot with ClockGen for example.
This is the Advanced Chipset Feature page:
The last two settings are very important!
Remember! PC4000 memory will likely not work with these settings, for them I recommend 3-8-4-4 timings.
After you've find a sweet spot for your CPU, try lowering the first four settings (called timings). Lower are faster.
As always, use your favorite stressing program to make sure your system is stable. I recommend Prime for stressing,
ClockGen for overclocking and CPU-Z to keep an eye on clocks.
