Abit KR7A multiplier reset after rebooting!
smashdml
I've got a very strange problem with my Motherboard.
Everytime that I reboot my machine, the mainboard uses the 10x multiplier instead of the 12x I've selected.
I have to get into my bios and adjust the multiplier back to 10.
When I reboot, I enter the bios again and adjust the multiplier back to 12.
When I reboot the second time, the problem is solved as long as I don't reset or power down!
Does anyone have the same problem and even better, has a fix for it?
My config:
Abit KR7A-Raid
300w power supply
AMD Athlon XP 1500+ ~ 1900+
2x 256 mb ddr 2100
leadtek geforce 3TI 200
SB Audigy player
IBM 40 gig HDD
Welcome To The Forums!!!!!
.....and to the addiction:eek:
Sounds like you have not unlocked your CPU yet. The BIOS has the option to change it but unless the L1 Dots/Bridges are not connected properly it will not have any affect. If you have anymore questions feel free to ask them.
L1 Dots/Bridges;
HOW TO CONNECT THE L1s & MATERIALS TO USE:beer:
PS Do check out all the links that I have posted. There are a few of them & also the hidden one :D.
