KT7-kt133 chipset-100FSB
KT7A (R)-kt133a chipsaet 133+FSB settings-IDE RAID
KT7E-kt133e chipset-100FSB supported but all boards teste have hit over 133-usually bout 145mhz-no RAID-new chipset-seem to be great
Rather than tell you LikuidFusion has given you the facts to let you decide
these facts being :-
(1) The KT7 mobo has a kt133 chipset.. which only supports a FSB of 100 mhz
(2) The KT7A mobo has a kt133a chipset.. and supports a FSB up to 133 mhz (and there is a model that has raid - Abit-Kt7A-Raid)
(3) The KT7E mobo has a kt133e chipset.. and officially supports a100 mhz FSB however all boards tested so far can run a FSB of over 133 mhz .. It is a no RAID-new chipset and seems to work well
Obviously as the KT7A (KT7A-Raid) and the KT7E have a major advantage over the KT7 as both are capable of running at a higher speed FSB.. however the KT7E does this higher speed FSB unofficially
I use the KT7A-Raid and think its a awsome motherboard
