- Dec 20, 2000
Won't fit properly!
I put in the 8 studs that correspond to the holes on the board and they line up but about 0.5 cm out on the top left one and the others except a couple aren't quite right.. I can get it almost perfect by pulling the side of the mobo tray (back) to the left and then pushing the mobo.. but I think it requires to much force to do so and I can't get the screw in even when I do that.. and also when I first looked at the mobo tray it twists a little like a very slightly bent peice of tin or something, making it uneven.. what the hell do I do? this is the first time I ever build a comp from scratch and the first time I mounted a mobo. what SHOULD happen?
