Hello. I have recently been talked into getting 2 Athlon T-bird systems instead of 2 PIIIs. Jim Roseberry at www.ProRec.com seemed to know his stuff...he's the guy who benchmarked the Athlon against the PIII, so he convinced me it will be cheaper...and even better!
I had done some research on the motherboard and chip for the PIII...but now I find that I'm really new to the world of Athlon. I'd really appreciate a little bit of help here.
I read most of the articles in this section and I found them very helpful. It seems the 2 main motherboards in use are the KT& and the A7V.
I went to PriceWatch to get some price ideas and I found some differences within the KT7 and the A7V specs...they don't all seem to the the same.
First of all, I suppose that SOCKET A boards are more common (cheaper also?) than SLOT A? Is SOCKET A the type I should go for?
The Abit KT7 also has a RAID version. Which is best?--I won't be using RAID.
I noticed both the Abit and Asus board have UDMA 66. Previously I was looking at boards (like the Abit BX133) with UDMA 100 IDE controllers...but I'm not sure if any HDs actually reach that speed. Please let me know if UDMA66 will be fast enough for my IBM DeskStar HDs.
I also found an Asus A7V PRO which says that the only difference is that it doesn't have DMA100 making it possible to OC 1MHz more.--This threw me off a bit.
Is the KT133 the best chipset for Athlon T-birds?
Lastly, when going to PriceWatch for bothe the Asus and Abit boards, they start off with some RAM ads. Do you need to buy a certain type of RAM for Athlon boards using T-bird chips? I know CAS2 is the best...but it's also the most expensive and since I'll need to buy a total of 512MB (between both computers), it will run me dry!
Thanks so much for your help and answers.
Best Regards,
NTL
Best Regards,
NTL
