How do I get the new rev. 1.04 Asus A7V board? I haven't seen that specified. Is it a whole new board than the original A7V?
Is the Abit KA7 any good?
I can probably wait only 3-4 more weeks before needing to buy the board and all...do you think the new KT133a chipset will be out by then? Do both the KT7 and the A7V have KT133 chipsets?
What about CPUs? Will a T-bird 800MHz OC to 1GHz? Is there a special brand or plant that I should look at for the CPU?--Or are they all the same? Should I OC? The 800MHz chip is about $100 while the 1GHz is about $171, so because I'm buying 2, it will make a difference and I could really use the saved money...if OC'ing is a good solution.
TX,
NTL
TX,
NTL
