OK, I'm new to overclocking and have a question I'm sure you guys can help with. I just upgraded to a kt7a motherboard, 800 MHz duron overclocked to 936 (8x117). It will not boot with greater than a 117 fsb because I'm using PC100 ram. Can I set the memory to run at a slower speed than the PCI clock, allowing me to get up to a 133 (or higher I suppose) FSB?
Another question, probably silly but, how do you change the CPU FSB Plus setting in the bios? It tells me to enter a number, but I can't type or change it.
Also, my temps have increased from 39 C @ 800 Mhz to 45 C at 940. At what temp would there be reason to worry? Thanks for the help!
DC
DC
