Abit KT7A MoBo "weird problem" Please Help if u can
PasoDuron750
This is an E-mail I sent to ABIT, Please comment if you know whats up. Thanks in advance
To whom it may concern,
I recently purchased a KT7A MoBo. I installed it in and Antec Full tower. I upgraded the Power Supply to a Sparkle 300watt unit.
Here is the system specs
KT7A
Duron 750
128 MB of Mushkin Basic PC-133
Maxtor 10GB 7200 RPM
Iomagic Sound Card
Kingston NIC card
Elsa Gladiac GeForce 2 GTS 32MB video Card Nvidia 6.50 driver
4x4x24 CD Burner
50X CD drive
Ok here’s the deal. I ran it stock for a while. I then over clocked the chip. No problems. My multiplier is at 8.5X113. Running at 962 stable. It will not run at a FSB of 133mhz even though I back off the multiplier to 5.5X133. Wont even post. Well now when I shut down to change peripherals, like speakers, keyboards or mice. The computer does not post. I try the insert key which is totally worthless. The only way to get back in the bios is to pull the Lithium Battery out of the board for about 10 minutes. Then I have to set up EVERYTHING again. This happens when its over clocked and when it is set to defaults. I have 4 way interleave and memory timings set to FAST. The computer runs fine, I just cant change peripherals. This is very frustrating. I am not a “newbie” but I need some info. I have posted to forums talked to resellers and Gurus and they have never heard of it. Also when I try to change the multiplier to 9 it defaults back to 7. I am not trying to overclock recklessly I am trying to learn. I am happy with the product, it just sucks that when I want to use my headset I shut down unplug the speakers, plug the headset in and then NOTHING. The computer starts but will not post. Please Help. I can be contacted at 805-712-7224 to answer anymore of your questions you may have. I have always been told what great service you provide so I await a solution.
Respectfully,
Anthony M. Ey
Fiz
C:\%systemroot%\minidump
Well, I don't know about the reboot prob, but I think the multiplier resetting to 7 may be due to a bad unlock. What did you use to unlock it, I used a defogger kit(oops, mine isn't stable with any X.5 mult)LOL. If you used a pencil that may be the prob. When you set the fsb to 133 are you setting the ram to host-clk? I forgot to do that more than once and it was a real pain to get this started up again. I wish I could help you a little more but I have never really seen this prob on this board(I have a kt7a-raid as well). Good luck
Fiz
Hoot
Inactive Moderator
Twin Cities
Re-do the L1 traces. The KT7A will not let you select Host+PCI for memory when the FSB is above 122 Mhz.
Hoot
