Abit KT7A &(R) owners, READ!
OC-Master
Edmonton, Alberta
Ok,
Now that I have your attention, could you please post the highest FSB you could obtain in SDR and give the amount of MHz/CPU and Ram you use with 100% stability. Abit KT7A &(R) only please!,
Also, if anyone knows the ultimate AGP drive value for the KT7A, PLEASE spill out the batch number! I would love to hit 150MHz bus with AGP4X! So far, I have done it but with artifacts using something like EE I think.
Thanks in advance!
Mine:
Abit KT7A-RAID V1.1
145MHz FSB 3.5VCORE AGP4X : 150MHz FSB 3.8VCORE AGP2X
AMD Athlon 1.0C @ 1305MHz (145x9) & 1350MHz (150x9)
1.0GB Infineon Ram (512MB x 2 dimms)
AXIA
cw823
Honeybadger Moderator
Earth
Have you looked in the CPU database? Most posts lists mobo info..
Dagon
Southern CA
The highest Mine will go is 150, at Cas3...this is a 1.1v board.
I stick mine at 145 cas 2, turbo settings and it's Prime 95 stable at 1595 (11x I think). [email protected],vcore at 1.91
I don't know about the AGP driving spec's..
Hook
150MHz Runs, but not stable random BSODs.
It runs fine @ 145MHz.
2 Sticks of Crucial
256M Cas-2
64M Cas-3
BIOS settings:
256m Fast
64m Normal
CAS-2
Angry
My KT7a before it died, I had PC100 at 150 Cas3 1.85..this was with a 1ghz AXIA.
But this Asus A7v-133 only does 147 with the same memory...
But I was also using a PCI Voodoo3 3000 at teh time...
