My KT7A has the following set-up:
IDE1 - Acer 16x DVD
IDE3&4 WD 40Gb ata100 drives - Raid-0
I just added an IOmega cd burner to IDE2.
When the computer posts, it shows that it recognizes only the ATAPI DVD on IDE1. After "scanning devices", it lists the DVD on Primary Master, but it shows that the Secondary Master (as well as the primary and secondary slaves) as "None".
After loading the operating system, I can see via the device manager that it recognizes both the DVD as well as the IOmega drives. In addition, I can see through My COmputer that it has assigned a drive letter to the IOmega (as well as the DVD).
My problem is that the computer is recognizing the burner as only a CD-ROM device and NOT as a recordable devise. As such it will not let me write to the burner. I know that I have all the connections correct since I would can "read" from the IOmega.
Do I need to do something in addition to get the computer to recognize the IOmega as a recording device (the installation instructions did not indicate anything else). Also, why is the mobo not recognizing this device on IDE2?
Any help would be greatkly appreciated!
IDE1 - Acer 16x DVD
