Abit NF7-S v2.0 nForce2 ??
Turando
UK
will this board work alright with a duron 750 and twinmos 3700 256mb ??? this is not a permanent option but it needs to run with them. Cheers, Turando
I think so. You may want to check there site. Thats like the most competly opposite setup there a Duron with pc3700 ram. How did you end up with that stuff.
Got to Abit's website to be absolutely sure.
Also, you should check out the manual that came with the mobo, it might say it in there as well.
thanks for replys,
"I think so. You may want to check there site. Thats like the most competly opposite setup there a Duron with pc3700 ram. How did you end up with that stuff."
its a second system, just upgrading it bit by bity at the moment will be replacing the chip in a ew weeks, just need it to be running i that time, so thats why its using gonna have to stick with the duron ;)
Cheers, Turando
