Abit Se6 motherboard oc settings help
eagle
Hi does anyone out there have a abit se6 motherboard ?? the problem is i have a p3 700 flip chip and im trying to overclock it i have a alfa cooler seems to be keeping cpu cool anyway the thing is i havnt got a english manual to set the cpu up manually i have to relie on the soft menu in the bios but i have played with the settings and had my cpu running at 933 or something like that but when i rebooted system said cpu unusable something like that and had to reset the bios any ideas what settings i should be using or is my problem that i should be using the jumpers rather than soft menu ?
SoftMenu will do fine- make sure the "speed error hold" is disabled in the bios, and try again. It should take care of it for you.
