ABIT VA6
specialksl
I just setup an ABIT VA6 with a P3 450 overclocked to 504 for my son. The question/problem is, when it boots up it shows a P2. Anybody know why. I have the latest BIOS (TN I think). I tried to flash to version UU and it trashed the BIOS so bad I had to do a "hot swap" to re-flash it. Why is it showing up as a P2 instead of a P3?
Maybe cos 504mhz isnt recognized as a p3 speed?? so its tryin to categorize it.Not really sure but thats my guess.Dont worry about it tho, the performance will be the same.
Is it in a Slocket??
If so it may have a jumper to set it to FCPGA, or something. If it's on a slocket, check and double check the jumpers. It may be in a slocket that doesn't properly suppor FCPGA. I don't know, I'm mostly blowing smoke on this one, I'm not much of an Intel expert.
If it's a Slot based CPU, I'm stumped.
CPU identification is done by the bios interrogating the cpu. Sounds like the bios may have a bug. You might want to email Abit, they may be aware of it... Perhaps there aren't many people using the PIII-450 with it and they aren't aware- YET.
