wired (Apr 09, 2001 06:19 p.m.):
im trying to run dual p3 733s .....can anyone help me in setting this up in the bios......i wanna make sure they both are being used.......thanks
I have a vp6 myself, as dose tim, I'm sure he'll reply shortly, and probaly with a better answer than me, but here I go
Well forstarters the bios autodects the chips themself, but you probaly need to set the speed, I had to, for your 733mhz chips, hold del, enter the softmenu, cpu speed, look for 733 and select that, or go to user defined and manual set your multiplyer and fsb, which would be, 7x 133fsb.
after that safe changes and reboot, you should see it pop up saying something along the line of 733mhz, 2 cpu's.
thats pretty basic me thinks, but good luck anyways.
-Trek
*edit*
Oh by the way only a dual processor operating system (smp enabled) will actually put the second cpu to use, for example, win2k, and various flavors of linux.
*edit*
