You have to wire or cover the pins on the cpu to trick the mobo into thinking your using a different cpu voltage.
Its called vid pining.
You can find info on it and good info on your board at:
When vidpinning take special care to only go a little higher then your default CV or you could fry your chip if your proccesor is 1.7 default start out at 1.9 and see how that works remember you will need better cooling with the increased CV good luck
