Yes, it's the WA-2A. I was looking for it myself some time ago. It's only sold to OEMs though, so we'll never see it. It's WATX format like the Tyan Thunder although no onboard SCSI. It also needs the special PSU that the Thunder uses. Overclocking options I'm not sure about.
On the note of the K7D Master, I couldn't agree more. Hands down the best duallie AMD board around, especially for overclocking.
Multiplier adjustments (no others have this, AFAIK, CRITICAL to overclocking)
FSB speed adjustment
ALL DRAM tweaks
The Master-L is my recommendation due to an integrated NIC. This way you won't have to use a more-scarce 32-bit PCI slot for a NIC, which is good because they're limited. I have a Master-L and two 1.3 Morgans running at 1470 and 1.8v.
That depends. What type of CPUs will you be using? Also, what peripherals will you be running, i.e. expansion cards, drives, etc.
A pair of Durons, a 5400 hard drive, generic video card and 512mb of RAM will run fine on a 400w PSU, maybe even a 350w. For a non-stripped down "normal" system configuration I would say yes, go with a 500w PSU.
You dont need 500 watts for a dual AMD setup unless you are planning to use extrordinary cooling. Count on 80 watts more than for a normal single system. 400 watts will do fine.
