about Nvidia Inspector
You have to enable "Unlock Voltage Control" in Afterburner's settings menu. It's just under safety properties in the first tab you see.
Well that's odd...and unfortunately I don't know enough about the nvidia program to say that is is any good...
I have not had any success with nVidia inspector and overclocking. If it does what you want I dont see the issue.
As for MSI-AB have you enabled unofficial overclocking in the INI file?
I was talking about this bit
http://forums.guru3d.com/showthread.php?t=338906 said:
To enable the unofficial overclocking in this version it is necessary to edit the MSIAfterburner.cfg file located in the installation directory of AfterBurner (typically Program Files (x86) MSI Afterburner):
You need to alter the following:
Seek UnofficialOverclockingEULA field and add following text:
I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
Set UnofficialOverclockingMode to 1 to keep PowerPlay active (may not work on old ASICs), 2 to traditionally disable PowerPlay or to 0 to temporary disable unofficial overclocking path
