Would a dual xeon w3500 series work on my ml350 g6 sever motherboard?
D dtking23 New Member Joined Aug 25, 2016 Aug 30, 2016 #1 Would a dual xeon w3500 series work on my ml350 g6 sever motherboard?
ATMINSIDE Sim Racing Aficionado Co-Owner Joined Jun 28, 2012 Aug 30, 2016 #2 Was the W3500 series an option from HP for the ML350 G6?
OP D dtking23 New Member Joined Aug 25, 2016 Aug 30, 2016 Thread Starter #3 In the manual it says 5500 5600 series supported, but the socket and the ram that the w3500-s supports seems legit for that motherboard so I dunno..
ATMINSIDE Sim Racing Aficionado Co-Owner Joined Jun 28, 2012 Aug 30, 2016 #4 It's likely the BIOS does not include the microcode to run the W3500 series of CPU's.
OP D dtking23 New Member Joined Aug 25, 2016 Aug 31, 2016 Thread Starter #5 ATMINSIDE said: It's likely the BIOS does not include the microcode to run the W3500 series of CPU's. Click to expand... Is there any bios mod for this motherboard or some another way to update/change its micro code so it could run these CPU's?
ATMINSIDE Sim Racing Aficionado Co-Owner Joined Jun 28, 2012 Aug 31, 2016 #6 That goes beyond my knowledge in OEM systems. Your best bet would be a non-OEM motherboard which you know the support for.
