AC2 and old proxy
ThePunkGeek
Ontario Canada
Well today i got my AC2 in the mail so i took off the old stuff i got from radio shack and applied a thin amont.
the temps only droped around 1-2c could it be that i did apply enough or that the hs/f sucks?
the hs/f is pretty shity but will work till i can get one online it is an
antec and has 2 fans that run @ 5590 rpm
cpu run at around 33c
Sounds like you did it right. AS is better than the others, but not much. If you put to much on then you start to have problems.
