realms said:
go with onboard. Soundblaster= crappy support and some compatability issues.
Wrong.
The Ac97 sounds just terrible. I have it with the nForce3 mobo in my sig. But if you look close enough (at my sig), you can also see a SB Live 5.1.
I use the SB Live as my default sound option: my speaker plug in there and my headphones will occasionally take over. My case has front panel audio ports -- one for headphones and one for mic. Well, just for fun I wanted to test out the front panel with my headphones. Of course, the front panel could only plug into the motherboard, which equals onboard sound for the front panel.
After testing out the Ac97 once, I was disgusted. I was listening to Bjork at the moment and felt that her voice turned into this sharp, dissonent razor, instead of her natural, soft voice. In the interest of science, I suppose, I decided to test out several audio instances: I did a side-by-side comparison of wide-ranging music (from classical, to techno, to jazz) and then tried out a couple games (UT2k4, mostly). In all instances, the SB Live sounded miraculously better than the Ac97.
Hehe, after experiences such differences, I'm tempted to upgrade to an Audigy to see if the same rule holds >.< please don't make me spend anymore money
