- Dec 19, 2000
Acrylic, Polycarbonate, Plexiglas, Lexan; they are all interchangeable terms in most peoples vocabulary. Getting the terminology correct could save your project from becoming a disaster.
Of all four materials listed above there are really only two plastics involved, polycarbonate and acrylic. Lexan is General Electric's trade name for Polycarbonate and acrylics trade name is Plexiglas.
Acrylic = Plexiglas
Polycarbonate = Lexan
Why does all this matter? In two words I would answer "Impact Resistance." If you’re planning any sort of project involving one of these two transparent materials you will want to know the one major drawback acrylic has to offer. Impact resistance is the key. If you want your project to hold up for any length of time under normal use, polycarbonate is the material of choice. Acrylic has a very low impact resistance and is prone to stress fracturing. Polycarbonate on the other hand has impact resistance 30x that of acrylic. Polycarbonate is also a harder material than acrylic making it less prone to scratching.
Proof:
Acrylic / Plexiglas Extruded
Impact Strength 0.4 ft lbs / in
Hardness Rockwell M: 93
Polycarbonate / Lexan
Impact Strength 12 ft lbs / in
Hardness Rockwell R: 118
These numbers are for the most common types of each material. Higher grades of each material are available but can cost quite a bit more. Even with high grade acrylic and polycarbonate the trend continues. Polycarbonate beats out acrylic in all the areas that make a difference for our uses.
What can acrylic be used for? Window mods are probably ok as long as you’re not playing football with your case. ITX cases, mATX might be pushing it depending on design. For standard ATX acrylic is a very bad choice. Even if you don’t kick your case, micro fracturing can occur around high stress areas. Polycarbonate is more expensive than but the costs far outweigh the disadvantages of acrylic.
Here is a price comparison of what I paid for each material.
Home Depot 24x48 sheet of .25” thick acrylic $30
McMastercarr 24x48 sheet of .25” thick polycarbonate $45
UPS ground for 2 sheets was only $11.75!
Where can you purchase these materials?
Home depot usually stocks acrylic but polycarbonate can be scarce
www.mcmastercarr.com is an excellent choice for either. They even stock bullet resistant polycarbonate sheets!
I hope this is of some use in your future projects
~Bender
Acrylic = Plexiglas
Proof:
~Bender
