Acryllic waterblock hold down
TT120
Senior Member
Sacramento, CA.
I have 2 more of these Acryllic waterblock hold downs that my roomie made for me left, if anybody wants one, just e-mail me and I'll get them in the mail for free. Nylon nuts and bolts not included, just the little nylon one in the middle.
bah. Who needs a clip. DIRECT DIE IS THE WAY OF THE FUTURE!!!! muhaaaaa. Just epoxy it straight on there. And with direct die it's not even heavy no die crushing!
sorry. I'm obsessed.
Spode (Apr 21, 2001 05:31 p.m.):
Wouldn't you risk ripping the pins off the CPU???
You got mail! Send it to me! I relly need both of them.
I fried a 1gig T-Brid because the cheapo (BeCool?) waterblock clip broke the middle plastic tab off the mobo socket & the waterblock was just hanging off it. My 1gig T-bird burn up before I even know it. $175 down thr drain. Sad...sad.
Now I got a new AXIA 1gig, I don't want to use the same crapy waterblock mount again.
Tong
Sorry guys, They're all gone. They went quick. If I can get any more made I will post them here.
They are easy enough to make. Get some 3/8" lexan, some 6/32 nylon screws, whip out your drill and you are all set. I had made one from 1/8", but it wasn't strong enough, and cracked around all the drill points. The 3/8" is holding up fine. I would also recommend eliminating the center holddown screw, as it was partly responsible for chipping a TBird core.
Agreed unless there are pelts involved. Gotta try this with my $40 Duron.
Kenshin (Apr 21, 2001 05:54 p.m.):
nah, make the block as light as you want! Plastic! The water is the heaviest bit.
I'm gonna make a chiller for mine soon.
