- Jan 21, 2012
Hello everyone,
So, recently because of my Masters degree final , I needed a nvme drive to be able to pass-trough to a vm.
The one I choose after some research was a Adata sx8200 pro 512gb , brand new .
First thing i did when I got it was to mount it in the bottom m2 slot of my x570 tuf , at the time reaching the top m2 meant removing the first gpu, which meant removing my d15.....and the bottom slot had the nice heatsink .
All fine and dandy, booted windows started crystal diskmark and bam ....reads of 3000 ....not bad ..but the package says 3500 .
Tried as ssd 2999 something, ok this looks ok as other reviews had the same value there.
Getting annoyed, removed the cpu fan, the gpu , applied the stock heatsink that came with the ssd and mounted on the top m2 slot .
Woala , 3500 on crystaldisk .
In the meantime the project is done and i can turn back to gaming , so i upgrade the bios , configure my ram again and .....quck ..2700 -3010 read on crystaldisk ?
Ok , maybe the bios is bad, revert to the previous one, same, cmos reset , battery out of the mobo, same .
I'm kinda annoyed by this, the ssd is only 6% filled, it's les than a month old and it only had a ubunu install on it which later turned in to a windows install and thats it , no intensive read and write on the ssd.
What can i do? or should i just let it be ?
EDIT: just as I ran the benches again to screenshot, the speed of crystaldisk got back to normal .
Is my mobo acting up or is the ssd faking the speed, I'm very new to nvme stuff so any info is greatly appreciated.
