I am trying to get a new DDR ram, above are some of my option.
Now i'm using HyperX A (Winbond CH-5), Don't get 5-2-2-2 with it , I need to get tight timing than higher MHZ, mostly i will using it for DDR 400.
Anyone have those DDR above ?, if so please reply with the tightest timing you got wit DDR 400 and volt too.
Adata Vitesta curently avaliabe in local store is DDR 500/ 256 with only US$ 69 per stick, www.adata.com.tw
eventhough its DDR 500, i will run it at DDR 400, like i said Tight Timming
Twinmos Twister PC 3200, my friend using it and it only get to 5-3-2-2, anyone had it too ???
If anyone had those memory above and has been rip the heatspreader, coulpd you tell me please what chip they are used.
thank you, appreciate all the answer !!
