ADATA XPG Lancer RGB 32GB DDR5-6000 CL40 - AX5U6000C4016G-B
Amon_Rat007
So, this is what performance I get from this memory kit. I've compared it to other systems running this and it seems quite low...
I tried to replicate settings that i found here, but it was for an intel system and i couldn't get the system to be stable. Could anyone help me find the right settings so i can maximize performance?
I do want to add that I have 4x16GB so two kits of these.
I checked out zentimings to see what was up and i noticed that both fclk and uclk were lower compared to others i saw. I think i really need to optimize this, i just never dwelled this into overclocking or amd cpus
Since you run 4 sticks, you should be happy it works at 6000MT/s. In most cases, it doesn't post at more than 5200MT/s. The performance is about as high as expected. To make it run much faster, you need to use 2 memory sticks and tight timings.
You can still check if it runs at a 1:1 memory/mem controller ratio. I don't trust ZenTimings with some values, as it sometimes shows weird things, and it's not optimized for all memory series. It suggests that the ratio is 1:2, so memory latency is significantly worse.
I wouldn't waste time on additional timings, as they barely help with these processors, but these ratios are important to maintain optimal performance.
