Adding a Small LCD
soundx98
Cantundastan
Adding a small LCD to your rig. Very Very easy!
Had a bunch of questions regarding the LCD Video Screens in my rigs.
It’s a very easy mod so I’ll try and guide you through the basics of it.
Required :
Video card with simultaneous Dual Monitor Output capability - It’s usually S-Video!
(I think that started with the GF4200 series for NVidia. – check with Card manufacturer to be sure.)
LCD Video Display with at least one Video Input. I use “headrest” LCD monitors from the car stereo industry. 4”, 5”, and 5.6” can usually fit in a 5.25” bay but you’ll need to give up two to three bays if you front mount them. They are generally less than 1” deep. Or you can place them internally so they are viewable through a window. There are big differences in quality and resolution among the screens. Generally, the better the off axis picture the higher the cost.. You may be able to find something on eBay or at your local Mobile Video Specialist. Prices can vary from $50 to $400. Some units are equipped with multiple Video Inputs, remote control, OSD, and even built in speakers. Multiple inputs are great for adding a small camera or second video source.
Many units come with their own “input connection box”. This can be an advantage or a hinderence due to extra cable length (of course it can be cut, shortened and soldered.
S-video to RCA adaptor. This converts the S-Video to the standard RCA style inputs. You’ll lose stability and often get Black and white picture only if you try and modify the S-Video connector. It does use a resistor/capacitor network to combine chrominance and luminance.
S-Video to RCA information
http://www.pccables.com/70714.htm
Here’s a generic video on how to set up the card for dual monitors
http://www.svideo.com/displayvideo.htm
RCA Cord to connect the S-video Adaptor to the monitor (12 to 18 inches long)
Some type of Molex connector to power the unit from your existing PSU or an external 12v PSU (wall type). Some overclockers don’t like the drain on PSU but the LCDs don’t require much wattage.
Solder, tape, heat shrink tubing or whatever to finish electrical connections.
Mounting Hardware du jour (screws, nuts, bolts, brackets) to Mount the LCD screen securely. Some folks will want to fabricate their own metal brackets and drill holes. Depending on screen and placement I highly recommend the use of 3M double sided Exterior tape #4010 and #4011. Super strong and used for mounting mirrors and such. You can also pull the LCD off if necessary or if the location doesn’t seem proper. (Makes sense not to block off the CMOS jumper or screw up airflow within the case obviously.)
Even if used only temporarily. It’s nice to have the tape at hand.
Screen – Shroud – Remote Control – Power Connector and Filter - Video Input box - Monitor Cable (this is NOT an S-Video style plug)
Out Of Box
Dual Inputs
Dual Outputs
This is the Fahrenheit T-6502HRS. We sell them for $299.99. Those are 7” screens above it in their custom headrest. You may be able to get a 8” or 9” as well. The actual “viewing area” of the screen goes up pretty dramatically as screen size increases. Remember the screens are measured diagonally.
Like I said, easy as Hale.
Bit-tech has some excellent info if you want to dive into modding an existing LCD.
Let me know if you have questions. Be more than happy to answer any specifics.
Since all my case have "side windows" I always am looking for a good scratch remover/cleaner". I am absolutely in love with Novus 3 step. You can pick it up of eBay for around $25 in 8 oz sizes. Make sure you pick up a case of elbow grease as well. :D
