Adding an internal exhaust fan??
Da Whip
Senior Member
Sunny Florida, you can keep the midwest!!
I am in the middle of building my new full tower and am laying out my fan locations.I have a 120mm(90+cfm) in front sucking in, a 120mm on the side blowing on the GPU and CPU, a 120mm blowhole and 2 -80mm above the PSU sucking out. I am considering adding an internal 92mm fan(50cfm) between the upper and lower case to help remove the lower case heat. OOps, I also have an Ultimate HD cooler located in the middle for my Deskstar. Any comments good or bad on this setup.
Da Whip (Feb 04, 2001 08:35 a.m.):
If you have the space, install one of those "slot style" cooler fans. These remove a lot of air from down in the expansion card area, which is usually a dead spot for cooling.
I've got a mid tower setup like this....:
fan, in, lower front of case
fan out, 1/3 of way down from top, back of case
fan out, "slot" type (mounts in open expansion card slot) between my AGP and ethernet cards
my case temps never go more than 5 degrees cel. over room temp.
At some point, I'm gonna get one of those HDD coolers that mounts in a cd-rom bay. I still have an open bay directly in line with my cpu/slocket assy., so I might not even mount the HDD in it, just let it blow straight at the cpu.
I read in a couple of different magazine articles, and a few places on the web, that more exaust fans than intake is the best way to go.
You can pump a ton of cool air in, but if it's not getting OUT as fast as it comes in............
Mr B
I like your thinking. I am thinking of doing something similiar to my machine. Right now I have the following
1 intake in the lower front
1 blowing out right below the PSU
1 of the HDD coolers (not with the heat sink)
and the power supply fan
I an thinking of adding one fan on the top by the PSU and one blowing out on the side by the CPU.
