- Nov 26, 2002
I have an Antec 1080 case with the insides pretty much full of tubes and cords. I fit everything in there, including the eheim 1048 pump, D-Tek heatcore, with a shroud and 120m fan. The fan is pulling air out of the radiator, and it is at the bottom front of my case. I have two Panaflo L1As on the rear of my case.
Currently it is 20c (!) in my room. My case is 30c. That's 10c difference, and that is horrible. Would adding another shroud and 120mm fan on the back of my radiator (blowing air ONTO) make a difference? Or should I change my two panaflos for somehing else?
Thanks
Summary: Two rear 80mm L1A fans, one radiator with one 120mm fan sucking, not blowing near the bottom front of my case.
Thanks
