dannyk (May 25, 2001 10:25 p.m.):
I just got one made by Enermax. It has about a 10" long heat sensor wire that you can locate anywhere it will reach in the case. Fan speed is continuously variable from 1800 rpm @ 25C to 3100 rpm @ 85C. Very quiet and inexpensive!
Hey, I did it! This is my first post!
stool (May 25, 2001 11:51 p.m.):
Go to http://www.allelectronics.com In the fan section you can find the Nidec BETA V 92mm fan with built-in thermistor. It is catalog# CF-95
sifu quoc (May 26, 2001 04:52 p.m.):
where can i find the digidoc? i was going to build my own fan controllers, but the 12.5 watt 25 ohm rheostats cost about $20 a piece from digikey and mouser... too much for me, because i need 3-4 of them...
