Silicon is in your PC. If you're lucky, siliconE is in your girlfriend.
Can you tell us the fps you are getting with the games you play.?
Btw OP, u have to much money!?
Use the free version of Fraps.
Not anymore I dont. LOL
Thanks, never seen that before.
Tri-fire is nice so far - in BENCHMARKS...
Is it all worth it though I ask, as benchmarking is fun, but I havent managed to play a single damn game since going trifire... Nothing but crashes and grief. Drained of it.
Ya, that might be a good idea. If that doesn't fix it, then maybe try with 1 card, then 2, then 3 way. It might be a bad card, but it is unlikely if it passes benchmarks. Just figured I would mention it.
Yeah, the very latest ones, havent helped at all, may go for a whole re-install as had to add a MOBO and card at same time, not always the best news for windows.
