Advantages of cooling the chipset
it will help you with higher fsb speeds and could help stabalise an overclock you are having problems with, it varies from chipset to chipset
harming the chipset
how do i know if an overheating is damaging my chipset - the northbridge mainly?
Generally, there won't be enough heat to damage the chipset, assuming you have a couple good case fans circulating air properly. But cooling the motherboard chipset, especially the northbridge chip, helps with higher FSB stability and might help prolong the life of the chips.
