- Dec 15, 2010
- La-la-latvia AKA Middle of Nowhere
Hello all you people (or at least those, who aren't too busy playing Fallout 4, lol)!
I've gotten a little rusty, without any gaming and using laptops only... So I need a quick rundown on the current state of affairs and suggestions for a cheapo gaming build.
At the moment, there isn't even a budget set for the project. I'm more than OK with my EliteBook, but it would like to have a small gaming rig for when my kid visits (divorced, seeing him on weekends) or whenever I feel like doing some gaming myself. Besides that, only other use it will see, is media playback. That is all. For work I have my lappy...
So, the only thing that's more or less set in stone is the form factor. It will be an ITX system. I'm short on space, and I just like compact stuff. Actually never owned an ATX/Full tower system, heh.
The case I've set my eye on a Sugo SG13, CM Seidon 120 for cooling. Not certain about PSU yet, but either way, a modular unit and I would shorten and re-sleeve the cables to make it all clean and pretty...
The part where things stop being as clear is the CPU/GPU/RAM.
I know that in theory I could try to get a H170 + Skylake i5 + 16Gb RAM + GTX960/R9 380, BUT... that's not exactly what I would call cheap. Actually I'd want to spend a lot less than that, if possible. Buying stuff second hand also in an option I am considering...
So, to sum it all up - can someone give me a hand and brainstorm some? Any Ivy Bridge/Haswell alternatives worth looking at, that would cost significantly less? i3 instead of i5 perhaps? Maybe even AMD?! Older gen GPU? What would you get, if in my shoes?
Many, maaaaany thanks!
V.
V.
