Advice needed
Jokkmokk
I am thinking of going RAID now again after two years without it and need some advice. Last time I had RAID was with two IBM "Deathstars" which I finally gave up on (to many crashes) and bought this Seagate 80 GB I still am running.
I need more storage and I am thinking of going RAID since i remember the amazing speed. How safe is it to run SATA RAID nowadays? Any crashes? I cant tolerate the regular crashes like my old IBM:s gave me.
I am thinking of this setup:
2 x SEAGATE BARRACUDA 7200.7 120GB 8MB SATA
1 x Adaptec Raid-1200A ATA100 2-channel Highpoint HPT370
What do you say about that? Any other recommendations? Or should i reconsider and buy one single harddrive?
Cornel
Fl
I don't think there is any point in making a SATA RAID with the harddrives you chose. There won't be any performance increase when compared to a IDE RAID and that's because the hard drives are limited by the mechanical parts in them. So I would say don't pay the extra premium for SATA hard drives (unless you change your mind and go for two Raptors)
J
Jokkmokk
The reason why I selected the SATA ones is that I can get them for the same price as normal IDE-drives. The reason why I chose Seagate is that they are supposed to make the most quiet disks out there in my price-range.
Raptors... arent they 10000rpm (=noise)?
Does anybody have any experiences with similiar setups?
Cornel
Fl
Your setup should be ok then...
I was thinking mostly at the fact that you can get IDE hard drives at very low prices (after MIR) at your local retail store. I got 2 WD800JB for 50 dollars each, they are running in SATA RAID0 (Silicon Image Sil3114 onboard controller) using this adapter. Everything is fine so far... And fast:attn:
