- Oct 13, 2011
A while back, I built gaming computer and my wife liked it so much that she has staked claim to it. I was there by banished to a cheap laptop, which was fine at the time because I was working more than gaming. Now, I have more free time and figure it's time to upgrade from the laptop. The new build will be for gaming and general use with little to no OC (the current laptop with average 5-15 fps on lowest settings and that's being generous). I would like to keep it under $1000 including Monitor,Keyboard,OS, and Components (I'm kind of looking at the best Price/Performance build I can manage, so if something can do near the same for cheaper, I'm going to go with that). I have put together some stuff that caught my eye and figured it would be a good starting point (I kind of have my heart set on a SSD and I'm fine with the smaller size because I manage my storage regularly and never have needed more than 250 GB).
GPU: $214 - XFX Radeon R9 280 3GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150705
CPU: $159 - AMD A10-7850K Kaveri
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113359
SSD: $110 - Crucial MX100 256GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148820
Mobo: $66 - ASUS A78M-A FM2+
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132080
Power Supply: $50 - Corsair CX500 500W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
Memory: $50 - G.SKILL Ripjaws 4GB (unless you think I need more...)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
Case: $50 - Corsair Carbide
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139041
Heatsink: $30 - Cooler Master Hyper 212 plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
OS: $100 - Windows 8
http://www.newegg.com/Product/Product.aspx?Item=N82E16832416776
Drive: $20 - Asus
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Monitor: $170 - Asus 23" 1ms
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236305
Keyboard: $50 - Microsoft sidewinder
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109191
Total $1069
So, I am currently a little over what I would like my budget to be. Some advice on anything you might see that could be changed to make it cheaper, faster, more compatible, or any insight would be nice.
Edit: I would also like to keep it open for things in the future, upgrades and the like (maybe higher resolutions or additional monitors)
Drive: $20 - Asus
Total $1069
