- Feb 7, 2013
Hey,
a friend of mine is in need of a new computer and therefore another friend and I tried to put a system together that offers him the best for the buck. His limit is 400€ (520 USD).
My original set up already exceeds that limit, however since he will buy it in june, we have some time to compare prices.
https://www.mindfactory.de/shopping...2203454def02e2568c407c3ae66febc729d1ad8a6ca53
This would be the system. Some things we are not sure about is:
CPU - Im sure the phenom would be the much better choice over a FX 4170, while my friend says newer is better
Our friend won't upgrade that machine, he buys it now and keeps it as long as it runs, so I think using an older socket is not too bad.
Mainboard - He once was not content with an Asrock board, but I've seen the extreme 4 and 6 series to be recommended a lot here, and the extreme 3 is only around 5€ more expensive than other mainboards on that site.
PSU I chose the 430W out of preference, we already agreed on the cheaper 400W BeQuiet Unit.
GPU I'd go with the 7770 as it is the same price as the 7750 OC and will perform at the same level, yet leaving headroom for OCing, even though OC is not intended on that build. But I like the option, depending on how difficult it is I though when we set up that machine for him, we could start off with a mild OC on the 7770 and leave him with that.
Any opinions? Any suggestions, part swaps are welcome. You are not restricted to the posted side for suggestions.
http://www.alternate.de/
http://www.hardwareversand.de/
http://www.computeruniverse.net/
are also eligible. Please do not post newegg links, since I experienced it more than once that I saw something for 100$ and the lowest price around here was 110€
Edit: I forgot to mention what the system is needed for:
It is mainly a multimedia PC, browsing, doing some excel / matlab stuff for college and occasional gaming. He doesn't require the newest titles to run on high (which would be ridicilous anyway with that budget), but he does enough casual gaming so a HTPC solution with Integrated Graphics would not work.
Thank you in advance!
