Advise on a leufken peltier kit
EDM17
i just bought a Leufken peltier kit form 2cooltech its the 52 watt version. I have never used a peltier and am looking for any advise i can get be it info or links to good articles about how to install it. I choose this one b/c its designed to work with my globalwin fop38.
Any info you could supply would be greatly appereciated THanks
right now i have a
1gig t-b
fop-32 hsf
abit kt-7raid
2 30gb ibm hard drives
winfast geforce2 gts 32 mb vc
soundblaster live
256mb of kingmax pc-150
mitsumi 52x cd rom
mitsumi floppy
kingston 10/100 network card
i ordered the peltier and a fop-38 to go with it
Hate to be the bearer of bad tidings... But
The 1 GHz T-Bird is going to laugh at a 52 watt peltier.
Even if you could somehow keep the hotside of the pelt at ambient temperature (impossible with standard heatsink) the heat the t-bird is throwing off would quickly overwhelm the TEC's heat pumping ability.
Sadly, I think what you'll end up with is a very inefficient heatsink. :-(
During my travails with water-cooled rigs, pelts, and T-birds I found that you're actually better off with just a good old Alpha PEP66, arctic silver and nothing else.
Thanks for all the advise i have decided to send it back and just stick to the fop-38 hsf and see what i can get out of that.
