advise please on cpu
EQBripper
I first wanna say is that this site rocks!!! next is sorry for my stupidity due to im new to this o/c stuff. i'm in the midst of building my new system and buyin a abit nf7-s v2 mobo...my first question of many is which cpu to go with.
amd 2500 mobile barton w/266 fsb or amd 2500 barton w/333 fsb
the mobile is about 20 bucks more and which can be o/c'd at the unblievable speeds i keep hearing.......
damn i love this site!!!!
dicecca112
MA, USA
depends what do you want, a good overclocker or a stable machine. Since all chips are locked except for the mobiles the best ocer will be the mobile. Your gonna get a stable machine with the 2500 barton. So it's up to you. If you get a mobile, make sure you have good cooling.
E
EQBripper
well this rig im building is for gaming purposes and a little encoding my home dvd movies...i wanna venture into good overclocking machine. so i guess i should pick up a mobile. the cooling fan i'm gonna use is a thermaltake vocano 9do you this this would work for me or should i pick up a new h/s
Josebmw
USA
That should work for a light o/c, depending on the overclock you are planning to do. I would recommend the Thermalright SLK-900 or a SLK-947U if you want to push the chip to 1.85v or more.
DJCorpse
West Fargo, ND
most people will tell you to go with a thermalright heatsink of some kind for the best air cooling. something like the slk-947u paired with a 92mm fan of some sort would cool well and run relatively quiet.
